EdgeAuto.ParmNull
Description
An internal function was called with a NULL pointer. This condition is not expected and is indicative of a possible memory corruption due to a software bug that needs engineering attention.
Remedy
Provide technical support information on the switch configuration using the 'show tech-support' command. Also, check the scalability limit in the user documentation and compare it with the current configuration using 'show configuration detail' command.
Severity
Critical
Message Text
Argument %arg% is NULL
Message Parameters
Name Type
arg String
